or power steering pump is nearly a dead short and puling more power from battery than the charge circuit can handle is very common when steering pump fails ,, also can destroy the battery as well
Based on this and what I learned at advanced auto, it's probably one of three things. My ABS is still running and whining after I kill nthe car, maybe that is draining the battery. Maybe there is a short in the power steering pump or the excess load of a now functioning pump is too much for a dying alternator. My alternator measured at like 14.01 while the vehicle was running. Finally that could be caused by a loose serpentine belt not the alternator itself being faulty.or power steering pump is nearly a dead short and puling more power from battery than the charge circuit can handle is very common when steering pump fails ,, also can destroy the battery as well
guess you already know what you need to doBased on this and what I learned at advanced auto, it's probably one of three things. My ABS is still running and whining after I kill nthe car, maybe that is draining the battery. Maybe there is a short in the power steering pump or the excess load of a now functioning pump is too much for a dying alternator. My alternator measured at like 14.01 while the vehicle was running. Finally that could be caused by a loose serpentine belt not the alternator itself being faulty.
most parts store rent those for free with a deposit, but in all likely hood they don't have perfect sizes in which case you might be able to find something around your house that may fit or at a local hardware store to do the bearing extraction.Here's a picture of you engine compartment fusebox as per the manual
fuse F8 is your engine compartment fuse for the electric power steering. It's a 30A fuse
Here's a picture of you passenger side fusebox your alternator,electric power steering fuse is F39. It's a 5A fuse
As well as a list of your ground connection locations on your car. Not that it is that important unless you might of been in one of those area's possibly servicing something.
I would check those fuses and see what's up you might be able to unplug the power steering fuse for the time being.
Here's a place to render a alternator rebuild kit for your alternator if you want. Double that up with going to that parts stores and asking if they have a bearing pull press kit available for rent. and just rebuild you alternator.
Here's the 105 amp alternator
and here's for the 120amp alternator rebuild kit.![]()
Alternator Rebuild Kit; Regulator, Brushes, & Bearings 2002-2008 Mini Cooper S (with Denso 102211-2230, -2231, -2232, or -2233) - 11049RK
<h3>Premium Voltage Regulator, Brushes & Bearings</h3> <ul> <li>Voltage Regulator 12 Volt, A-Circuit, FR-IG-L Terminals, 14.5 Voltage Set Point, Denso 126000-3300, Suzuki 3250052D00, other: IN330</li> <li>WBD Bearing 55222 17x52x16mm</li> <li>WBD Bearing 53514 15x35x13mm</li> <li>Brush Holder...www.maniacelectricmotors.com
If it is your alternator and you don't want to pay for a whole new one.![]()
Alternator Rebuild Kit for 2002-2005 Cooper with 120A SG12S073 Regulator, Brushes, Bearings
<h3>Description</h3> <p>Alternator Rebuild Repair kit </p> <ul> <li>Voltage Regulator with Brushes L-FR Terminals for Valeo on Mini Alternators, 12 Volt, B-Circuit, 14.5 Voltage Set Point Replacing Valeo 593551 Other; M552 </li> <li>Bearing NTN 53500 15x35x11mm Ref 6202</li> <li>Bearing NTN...www.maniacelectricmotors.com
Pulled those fuses and I still have power steering. Battery light is still on and I think I can hear my ABS pump continuing to run after the car is stopped. I tried pulling that fuse but whatever the noise is, it won't stop unless I disconnect the battery. Sounds like an electrical whine.Here's a picture of you engine compartment fusebox as per the manual
