I have come to learn I need to trust the practical application of any item in the car, also the functionality. Example the high pressure fuel pump is gonna pump regardless. cooling it off only to preserve the life of it is nominal. It is operated by the camshaft. Low fuel pressure would be the low level fuel pump in my own opinion. thankfully I have not had to purchase a HPFP yet. I have had it replaced under warranty. So they say.
What you want to hint at; I think. MAY be a problem is Vapor lock. But I would not know. I think it would be a different issue to cause a drop in fuel pressure.
Did you remember to prime your low level fuel pump before ignition. Priming the low level fuel pump(standard fuel pump in any other application than forced induction in gasoline automobiles. Priming the fuel pump is Standard procedure. Though I have never installed one on a Mini Cooper.
I know how I would install on in the mini cooper, concerning the low level pump. I would pull the low level pump back out again and try again. If I did not prime it. It might of even destroyed the low level fuel pump if you did not prime it correctly. Sounds like it is working getting fuel but at the cost of half the fuel pump power getting immediately worn out; from not priming it.
It's pretty common for the low level pump to completetly go south right on ignition from not priming it. And it is a Advanced machanic mistake that can happen ever so often. So don't get that angry if your low level is destroyed.
