1 - 20 of 22 Posts
I am consider to purchase H&R sway bars. It seems there are 18mm and 19mm rear sway bar. Anyone notice a major different for the 1mm different?
Thanks!
Harold
It might not sound a lot but the torsional stiffness will be greatly increased. I don't have the official equation to hand but i'll estimate the 19mm bar will have 35% more stiffness.
-Rob
MINI2 co-founder
we use both of the bars at the shop - one of our project cars has the 18mm and one has the 19mm....we are still working on getting the suspension just right on the car with the 19mm bar, but with the 18mm bar the car is perfect - we have had several other racers besides us in the car as well and feel the car is perfectly balanced. Remember a sway bar is only part of correctly setting the suspension up - and it seems that many people like to recommend the largest bar out there in hopes that it will make up for everything else...it won't. Additionally with some of the larger bars you will run into situations where you will get oversteer...99% of people out there have no idea how to handle oversteer properlly and will end up some wrecking their beloved MINIs. I have the 19mm on my personal car and the other weekend at the track i was able to get the back end to do whatever I want...but the key is - it was doing what i wanted when i wanted it to...no the other way around.
We have a special going on right now with the 18mm bars for $146.25...the 19mm bars are $179.95. Check them out at PROMINI.com
Mini Mod
Which setting? The H&Rs have 2 for the rear don't they?
Also, are you running the H&R front as well? That would make a difference in balance too.
MINI2 co-founder
Both project cars are running the 27mm Front bar as well - my personal car so far only has the 19mm rear...all rear bars are set on the stiffest settings...before the next track event i'll be stepping mine down to the softer setting...i find that on the street the stiffer settings works best and on the track I have a feeling the softer will be better as on the track at high speeds you have alot more control over the rear of the car then you do on the street.
Mini Mod
Thanks Casey.
I have the 22mm Alta bar on the softest setting.
At my limited skill level it works pretty well for me. But then I'm used to it.
MINI2 co-founder
have you used it on a track? If it has similar characteristics to the H&R bars - which I'm guessing it does - since Alta uses H&R to make their springs - i'm guessing they may also use them to make their bars(but not positive)..but on a track I would personal refuse to use a 22mm solid bar. On the street is one thing as the speeds, corning speeds, braking points, etc are drastically different then on a track, it may be alright but on a track I would be very leary of it...with my 19mm bar I can very easily get the back end to come around if i want - but 99% of the time it does exactly what i want - the car 4 wheel drifts coming out of corners perfectly...the car doesn't really push at all unless i heavily overcook it into a tight corner..but in sweepers i have zero push....now on the street you want a car that pushes...it really is not a safe vehicle on public streets if the car has oversteer....push in a front wheel drive car is easy to handle - as everyone's instict to correct the problem is correct - lift off the gas...but the problem is 99% of drivers out there will also do the same thing when the car is oversteering...then your just hoping there is no traffic near by for you to take out and you only take out your own car.
a 22mm bar is really a dedicated autox bar...not a street bar or a track use bar.
Happy Trudger
Casey, sounds like the "rule of thumb" I've been given by a racer/suspension friend: "If the track is fast go softer, if more technical go stiffer". Of course, rain/wet also calls for softer. I have a 3 position Mini-madness rear bar and have used all 3 settings at the track.
I also have the H & R front sway bar. Question: Have you ever set it to the stiff setting. I imagine if you have, you would have the rear on full stiff. Just curious what has been your experience with the front at full stiff. I haven't done it yet.
Mini Mod
Well, since I only auto-x a little and don't really push the car hard on the street I guess I'm OK.
On some of the bigger courses where I may enter sweepers at 45-50 MPH the car generally still pushes. If I screw up I can get into oversteer but you can do that with anything if you F up bad enough. Not that I've done that :rolleyes: :D.
I'll probably never get to do real track time and if so it won't be competitively. Hopefully just for some learning experience. I'll assume I'd be with someone more than qualified to show me the right thing to do.
Good stuff as usual Casey, thanks.
MINI2 co-founder
obehave - cheers bud
nearlynn - the H&R front sway bar is not adjustable - it only has single attachment points.
Happy Trudger
Casey, too many companies with "H's". I have the H-Sport fonrt swaybar. Just checked and saw that the soft setting is just +16% and the firm setting is +27%. Really not a huge deal, especially compared to the percentage increases that rear bars effect.
S, I guess I'll be testing and tuning with the front next time out.
Discussion Starter #13
Dear Mini friends,
If I keep my stock suspension of the Cooper S sport package. Would it be better to go with 18mm or 19mm? Can anyone tell me what size is the original rear sway bar for cooper S?
Thanks a lot for your information, as a newbie, I really appreciate that.
Harold :D
The Mini Family Sponsers
LMB
Probably better than doing the springs first in my opinion, a massive difference in cornering, the oversteer is far better than understeer, I think a great upgrade no matter what one you buy...
...where´s the any-key?
rasp said:
LMB
My only concern is bottoming out, I drive over speed bumps every day.:(
The Swaybar will not make your car any lower and makes hardly no difference to ride quality but I know exactly what your saying about these pigging speed bumps...
Mini Mod
harold said:
Dear Mini friends,
Harold :D
OEM on mine was 17mm.
Like a lot of the above thread indicates what to use has some to do with what you plan.
Me I'd say go with the 19mm.
1 - 20 of 22 Posts
