So, took the old 'un for its MOT fully expecting it to fail on the brake lines as it's been an advisory for the past 3 years but ti actually only failed for having no bake lights.
As I've got to wait till it stops raining before I do anything(possibly a week or so from now) I thought I'd do some research if it turns out to not be anything obvious.
Checked the fuse (if F6 is the correct one) and it's fine. Next stop will be the switch.
However, there are also some other electrical gremlins that have appeared but as my wife drives the car I'm not sure if they all failed at the same time.
- The front 12v accessory doesn't work
- Opening the driver's door with the key (bought the car without the remote fobs) doesn't unlock the passenger door.
- The power lock switch in the dash doesn't operate the locks - it sounds like the locks are operating when the switch is pushed in one direction but they don't pop up or down and in the other dirrection there is either nothing or a faint click from the footwell.
- On occasion (maybe once every few months) turning the ignition key does nothing. No lights, no clicks, totally dead. The cure ? Leave it and try it after 10 minutes
or so. Always starts. - On the way to the MOT the steering felt like it went light at speed then went heavy. Not sure this is connected as it does leak fluid due to the fact that somebody has used none synthetic fluid in the past and the seals are goosed.
