So assuming this is a fresh post following on from Here
Are you getting the alternator from the same supplier....If so do they have a batch of faulty regulators?
Or is there something demanding excess current from the battery?
Did you fully charge your battery prior to refitting the replacement alternator? If the alternator has to supply all the electrics and a flat battery that would give an excess current draw scenario.
Did you connect up the alternator with battery disconnected?. ie no sparking terminals inadvertently causing an electrical spike through the regulator.
Have you checked for excessive current draw at the battery with ignition off? Multimeter measuring amps between disconnected positive terminal and battery positive cable. Your looking for over a couple of amps possibly double figures.
Have you definitely got the wires to the alternator in the correct order?
Is there a wire that's chafed to earth and is taking all the current to ground?
I know that's many many questions but we're at a disadvantage not being with the vehicle.
