Hi there, my girlfriend has a 2005 mini one diesel with an overheating problem. At first I noticed going up hill the temp monitor would go max and then go straight back down. A few weeks after owning it we opened the bonnet to check water levels and found the cap was off, so it had run a few weeks with cap off. We filled it up, put the cap on and saw no issues (this was in july). Last week we drove a 40 min motorway run and the temp maxed out again. Water coming out the top of the cap etc (cap fully tight). The next morning the coolant bottle was completely empty (it had been topped up a few days previous). Since this overheat the car now struggles to start but when running the engine sounds fine, no loss of power at all (not that it has much anyway). However at the end of every journey, water is bubbling through the cap but temperature gauge stays correct (short journeys only). We have also noticed the fan is almost permanently on, very soon after starting the car.
We took it to a garage who diagnosed that the head gasket had probably gone, but they are not capable of repairing it as they don't have the tools. Now I'm wondering if it could be something else, as the engine sounds fine, the oil (which we haven't stopped up this year) is at the correct level and pure black, and it overhears up hill but coasting downhill it goes back to normal (but even at normal it bubbles out the cap). I checked the water this morning after driving it back from the garage yesterday and it is still at the correct level, doesn't seem to have lost much, but again even after that journey (around 6 miles), it was bubbling through the cap.
My girlfriend really can't afford to replace the car so we are hoping someone could give advice on other things to check, or if in your opinion it really could be the head gasket.
Thanks for your time.
