First off, I apologize if this has been addressed in other threads but I have not been able to find an answer.
I'm looking at a 2007 Cooper S Turbo with a seized motor. However, when I go to price up replacement motors the prices vary a lot. Are some just not compatible ?
What am I looking for specifically ?
I believe it needs a N14 but when I look at used motors on sites like ebay they only describe the motor as 1.6L for years 2004, 05, 06, 07 etc.
Is there a specific N14 for the turbocharged car or do both the turbo and NA engines work in either application ?
VIN is WMWMF73567TT81570
Appreciate it if anyone can give me some direction on this. When I use the compatibility chart on the ebay ad it says not compatible with the 2007 hatchback but the car is described as a hatchback so I am confused. Obviously I don't want to buy the wrong motor....
Thanks.
I am also in the same situation. I have a 2007 cooper s 1.6L turbo in need of an engine. I was just quoted by a service center at 10 grand to replace the motor. There is no way that this can be right is there? I have found a 2009 turbo 1.6 from a clubman labeled R55,56,57.
I guess my question would be is will it work being that I have an '07 R56? Are the mounts the same? I have not been able to find this answered anywhere.
will a 2008 mini cooper CLUBMAN S auto transmission engine fit in a 2007 mini cooper manual transmission?
yes they will, also the Peugeot 1,6thp engines are same as in 207 gti 175bhp if you get them in your country
