its the same engine in peugeot and citroen 1.4 prince engines below info might help, ie ep3 and ep3c engine numbers are same
1.4 litre EP3/EP3C (PSA)[edit]
The 1.4 L PSA
EP3 and
EP3C[9] is the smallest member of the Prince family with a stroke measuring 75 mm (2.95 in) and total capacity of 1,397 cc (1.4 L). Depending on application, power output varies from 90 to 95 PS (66 to 70 kW; 89 to 94 bhp) while torque varies from 136 to 140 N⋅m (100 to 103 lb⋅ft).
Applications:
and the turbo engines are below
1.6 litre turbocharged (PSA)[edit]
The
turbocharged 1.6 L unit adds
gasoline direct injection and has special low-pressure die-cast heads. It has an 85.8 mm (3.38 in) stroke for a total of 1,598 cc (1.6 L) of displacement.
At first, there were two versions on offer - the THP150 and THP175, also known as the
EP6DT and
EP6DTS respectively within Peugeot. The first was later updated as
EP6CDT and also a THP163,
EP6CDTM.
[9] There is also
EP6CDT MD - with lowered compression ratio.
For the THP150 maximum torque is 240 N⋅m (177 lb⋅ft) at 1400 rpm, remaining flat to 5000 rpm. Power output is 150 PS (110 kW; 148 bhp) at 5500 rpm.
Applications:
For the THP163 maximum torque is 240 N⋅m (177 lb⋅ft) at 1400 rpm, remaining flat to 5000 rpm. Power output is 165 PS (121 kW; 163 bhp) at 5500 rpm.
Applications:
For the THP175 (
EP6DTS, later
EP6CDTS) maximum torque is 247 N⋅m (182 lb⋅ft) at 1600 rpm, remaining flat to 5000 rpm. Power output is 175 PS (129 kW; 173 bhp) at 5500 rpm. An overboost function is available which temporarily increases torque to 260 N⋅m (192 lb⋅ft) between 1700 rpm and 4500 rpm in gears 3 to 5.
Applications:
In 2010 Peugeot released 1.6 THP engine (
EP6CDTX[9]) with 200 bhp (149 kW; 203 PS) at 5500 RPM, maximum torque 275 N⋅m (203 lb⋅ft) @ 1700 rpm. It featured
direct injection,
twin-scroll turbocharger and
Valvetronic variable valve lift.
Applications:
The
2012-2014 Mini John Cooper Works GP featured additional performance, with 218 PS (215 bhp; 160 kW) at 6000 rpm and 280 N⋅m (207 lb⋅ft) of torque at 2000–5100 rpm from a larger turbo and engine internals.
[11]
PSA has now released a new Euro 6 engine based on the THP in the following Engine codes:
- EP6FDTX - 205 bhp (153 kW; 208 PS)/208 bhp (155 kW; 211 PS)/210 bhp (157 kW; 213 PS) 1.6l THP Peugeot 208 GTi
- EP6FDTR - 250 bhp (186 kW; 253 PS)/270 bhp (201 kW; 274 PS) 1.6l THP Peugeot 308 GTi
- EP6CDTR - 270 bhp (201 kW; 274 PS) 1.6l THP Peugeot RCZ
