Been looking for ideas on what else I could do here.
Went to local store, no issues, came out, pushed the start button, nothing, thought I heard a buzz...like dead battery, solenoid...not enough juice.. Bump started the car drove home. Figured bad starter, replaced, nothing still. Did some more reading, checked voltage on battery, almost 3 years old 12.2v. https://100001.onl/ https://1921681254.mx/ https://happymod.site/ Good. Replace push button, same. Need to crawl under and check main cables I guess and voltage at starter. Need a second hand...son is home tonight. Motor was replaced and running for last 5k....Relay-noticed that three of the relays are the same swapped out....nothing.
Are there any other ideas here?
Thanks....
CAS unit maybe, or clutch pedal micro switch another one,
stick a volt meter on small wire to starter soloniod while someone press clutch and press button as to start,, if no volts then cas unit likely need a diagnostic scanner to look for codes and also bcm for faults as might be that at fault and signal lost at that point, if have volts at small wire when button pressed then starter, or earth cables from battery or live wire maybe cracked somewhere another maybe and these should be first places to under stand,,
That Cas unit theory is Valid. I have encountered that problem. It was a bad starter. Bad battery. Get a new battery and starter And alternator. In most modern circumstances. That is just how it is The car needs the electricity and the battery is the buffer for the alternator before going into the car. The Cas unit is expensive so I would leave that one for last. Not saying The car would not start With a bad alternator. The sequence of replacing those items.
Another thing might be where the key fob goes. If it is broken and needs to be replaced. If you have a negative Battery Terminal fuse that might need some researching before you go off and just start unplugging battery cables.
Replacing a starter is hard to do on the engine. Im trying to think for a minute. The orientation of how you connect the positive cable to the starter may come into play. Look over the wiring.
