What you would want to do is get a volt meter and unhook the starter connection grounding out the negative on the engine. Then putting the positive in the two prong connector. Having someone start the car looking for proper voltage from the connector. More than likely bendix solenoid drive went out on it. If you have the original bosch starter SR0466x.
Bosch (OE Reman) SR0466X Starter - Mini | 0001106018090 0986018837 12411489995 12411517328
You can get one heck of a rebate at this place. Provided you have the original. If you look under the car there should be a huge sticker with bright red numbers stating SR0466X.
