2012 Mini Cooper R56 Base N16 Manual
Morning... I continue with my project mini cooper base 2012 n16 engine and getting close. Trying to verify I have all the proper electrical connections and not wiring issues. So I endeavor to test continuity between the DME wiring harness to the field termination. For example I want to test continuity for the fuel tank vent valve from the terminal at the tank vent solenoid connector and the pin on the DME connector harness. To do that I need a diagram/map / pinout of the DME connections similar to the below. Does anyone have a copy of this for my vehicle or know where I could look for it??
Product Rectangle Azure Font Screenshot
Discussion Starter · #2 ·
FYI, to close this discussion out. I was able to purchase on EBAY a technical manual which had the complete wiring diagram. And after several weeks not knowing how to read the wiring diagram, I finally figured out how to read it and get the information I was looking for. Here is an example of what I found and if anyone needs help reading these let me know. cheers
Rectangle Font Parallel Pattern Number
