It won’t actually start like engine won’t run. But it does crank.By "turn over" do you mean start? Crank/turn over is the same thing. I ask as it makes a difference as to what you would do next to diagnose.
My EX Husband is the devil and he over filled it by 6 quarts. Probably on purpose.Also, 6 quarts extra doesn't make sense. It shouldn't take that much from empty. If you give me the full story of what's happened I will be more likely to be able to help.
Where and how do you reset this thing?? We have looked everywhere!!
It would be an expensive way to sabotage a car, probably best to assume he's just not a great mechanic.My EX Husband is the devil and he over filled it by 6 quarts. Probably on purpose.
Got you. I would suggest buying a can of easy start. Spray it in the intake when starting. If it then starts it is definitely a fuelling issue.It won’t actually start like engine won’t run. But it does crank.
Yes well either way I still need to fix it. It’s my 17 yr old Boys car. ❤It would be an expensive way to sabotage a car, probably best to assume he's just not a great mechanic.
Thank you!! I will give it a shot!!Got you. I would suggest buying a can of easy start. Spray it in the intake when starting. If it then starts it is definitely a fuelling issue.
