My 2012 Basic Mini with automatic transmission will not switch to the manual "paddle" shift operation ::frown::
When driving in gear it goes fine but the indicator light on the dash fluctuates between D and DS but no change in drive operations. If I try to switch to paddle mode, it stays in automatic.
The electric power steering pumps are prone to failure and were the subject of a recall. The failure is often caused by low power steering fluid or failure of the electric cooling fan. If you are lucky enough to still be covered by the recall (warranty), the dealer will make you repair all fluid leaks before they will install the new pump.
