Hi everyone,
I have some pretty bad roads around my house, and I recall bottoming out a few months ago when topping a rise and encountering some unexpected roadwork. I was amazed that I didn't have any problems.
Well, I actually did have a problem, but it didn't surface right away. Lately, I've been having problems starting the car - it produces a whooshing sound, doesn't kick the motor, and then produces a starter/ignition fault.
It's intermittent, and will now start about 2-3 times out of ten...
I decided after awhile that it must be related to the solenoid, so I took a look underneath - there was definitely some damage to the bottom engine bay cover, and viola, the solenoid had been hit in the impact, and finally has completely fallen off the starter and is hanging by the wires...
So the mystery is solved - I don't need any help with troubleshooting, but your advice on where I can find decent parts would be most welcome! The new part is over $400, so no go there. Ebay only lists a couple parts from the UK, and I've only found a couple of recyclers that might have the part, but they don't list the actual part number.
It's a Bosch LS-7649090 02, and another number shows 0 001 170 201.
I've got a manual transmission, and can find some recycled starters for automatics - anyone know if it's the same partno?
Also, I see starters with 03 or 05 after the partnumber, as in LS-7649090 05 - would a different suffix make a difference? I found a suffix 05 that only has 6k miles on it...
Who would you go to for a reburbished or reclaimed starter?
Thanks!!!
3gswish
Thanks!!!
3gswish
