215/45/17 with VOlks CE28N 43mm offset and M7 Sports Spring - "DOES IT RUB"???
Hi all,
I am driving a 04 production Mini Cooper S.Currently I am having a big dilemma
,am torn between either the tire size of 215/40/17 or 215/45/17 ??? The wheels I am having are Volks racing CE28N 17" with 43mm offset, and I will be lowering with M7 sports springs ,the drop for the spring is about 33mm as quoted from M7.
The 2 tires I am thought of getting are either Goodyear Eagle F1 GS-D3 or Toyo Proxes T1-S. The problem is that for 215/40/17 ,the Eagle F1s are having load index of 83 which is slightly below the recommended of 84,on the other hand the Toyos T1-S are having load index Reinforced 87(wondering how true of a fact is this 87
however to be on the safest end, I was thinking of going the route of 215/45/17 for clearing the slightly under load issue(was concern that the under load index would effect insurance and factory warrenty if anything bad happens). But as I will be having 33mm drop from the M7 springs, I am worried I will be getting rubbing when the mini is carring myself(abt 125bls) ,a passenger(abt 100bls) and some luggage loads (abt 50lbs).
Hope someone can kindly advise some thoughts on this??
Is there anyone out there running wheels of 43mm offset and and 215/45/17 tires ,at the same time lowered abt 33mm using M7 springs comment on my above queries?? Really need your help...
Thank you very much in advance for any inputs,
all are greatly appreciated.
Cheers...
Hi all,
Cheers...
