I have read several posts on the forum regarding this code. I would like some feedback as to whether people think it is the dreaded timing chain issue.
R56 N12B16A engine with 70k miles
We have had the car about 6 months now and it ran fine until end of October. It developed a bad misfire and started throwing blue smoke out of the rear on cold start up and after idle at traffic lights. I traced the misfire to a knackered plug - new OEM cured that.
A new set of valve stem oil seals has cured the oil issue, so all is good. As I had the cams out and reset the timing, I have reset the adaptions too - all was good for a short while until the code appeared. FYI - the timing is spot on, I have checked many times!!!!! In the process I changed the rocker cover gasket too as it was toasty to say the least
Further checks so far:
Both VVT solenoids - ohm reading around 9.6 ohms (all good). We have B+ at pin 2 when running and continuity back to the ECM. Removed and cleaned both VVT's. Have applied 12v to both, and both click perfectly. Played swapnostics with them, and still 287D is appearing. Tried to reset the adaptions again - no luck.
Checked and actuated the valvetronic motor with my scanner, and reset the adaptions - no issues there.
Scoped both cam sensors and am getting a good waveform - tried swapnostics again - no luck.
I have done another oil and filter change too, but to no avail.
At this stage, I would welcome any comments/feedback as to the way forward. We want to keep the car as it runs (ran) sweet and is fun to drive.
For the future, I am going to do all brakes/discs and brake fluid, oil filter housing gasket and gear box oil - any other thoughts please?
