30mm suspension lift install and geometry correction.
6565 Views 7 Replies 4 Participants Last post by  Dabbler Pete
4
Been working on the Clubman 'allroad' project over the Christmas period and installed the 30mm strut spacers front and rear.
With the additional height in the sidewall of the oversize tyres, this raises the whole car by around 60mm - 65mm ( or over 2 inches ).
279737
Strut spacers are polyurethane and look like this.
Install is easy, just remove the struts complete and fit the longer bolts along with the spacer.
Re-installing the strut had me scratching my head for a while, but I figured out it was possible to bolt up the top and then use a length of wood vertically under the lower sprint mount to compress the spring using a trolley jack (while the car was on stands) - then the bottom of the strut would drop into its carrier.
279738
Adding the strut spacer adds positive camber, so I needed to adjust the top strut mounts to restore some negative camber.
The top strut mount bolts are already slightly oval (but the stock setup uses a locating pin).
I elongated the mounting holes by 3mm towards the engine both sides.
Stock bolt holes were approx 13.85mm - I ended up with a little over 17mm.
Torquing down the strut bolts with the struts as close towards the engine as the longer elongated holes allows seems perfect (although I'll get a full alignment to confirm). Certainly the car drives exactly as it did before.
279739
Rear strut spacer install was super simple, the back struts are a heap quicker and easier to remove.
I installed adjustable lower control arms so that I could dial back in the correct geometry (as the stock camber adjustment on the rears does not have the required range).
279740
Here's a bit of a teaser photo of how the vehicle now sits.
I'll get some decent photos soon.
I've done a few hundred miles in it the last week and it drives very nicely (even pending a full alignment check).
279742
  • Like
Reactions: 1
What lift did you get? Lots of TF 2.5” options. An alignment cannot adjust your caster unless you bought a kit with adjustable control arms or geometry correction brackets.
Kodi nox
Hello Mark,
This is a 'budget' project so I bought 30mm strut spacers from a company called Tema4x4 based in Russia.
This 30mm, plus an extra 30-35mm extra in the tyre sidewall is what raises the vehicle by approx 2 inches.
Yes I agree that the caster is not corrected, I have only corrected the camber. The car drives great though !
I'm so loving this! I'm trying to do a build similar to this! What size tyres are you using on the new setup? Trying to figure out what size I can get away with a 30mm lift.
It looks like 205/70R15 (from a earlier pic)
Yes, 205/70R15
The steel wheels are Vauxhall Astra which have a different offset to widen the track.
