21 - 40 of 80 Posts
The Mini Family Sponsers
No offence midlifemini but I personally cannot see a 4 wheel drive mini in the future can you? as you mentioned and indeed what sums it up "a rumour" dont get me wrong it would be interesting but I just cant see it happening, I think 996gt3 hase some good points a couple of posts back inwhich gives good reasons why it will not never happen and I was putting the point accross that theres more chance my nan would get her V8 pacemaker before this car was ever produced..
Autox Monster
Quoted from:
http://www.wrc.com/en_GB/News/2003/008/2003_R_DE_FabiaHomologation.htm
Homologation rules in brief
To have a rally car homologated for the World Rally Championship is a complex process. At least 25,000 production cars of the basic model range, with a minimum length of 3750 mm, and at least 2,500 cars of the model from which the rally car has been derived, with a minimum length of 4000 mm and a wheelbase of 2440 mm, must be produced. With the Fabia WRC, this condition will be met by the production of the Škoda Fabia RS that was presented for the first time at the 2003 Geneva Motor Show.
The MINI is 5 inches too short for homologation for WRC. Until the MINI grow a few inches, NO WRC cars
RASP -
Whatever you do don't either you or your parents try and get a deaf aid via the NHS for your Gran!! The V8 model WOULD be out first :D
(Don't suppose anyone on here has tried it - no, thought not!)
MINIstry of Fun
I have no doubt that the MINI model range will change and expand over the years.
I expect there to be a proper roadster with a mid engined motor.
There will also be a model with a longer body that will meet WRC regulations, and it will be mid-engined and either rear-wheel drive or all-wheel drive. The extra body length will allow for a variety of engine sizes and types.
Once the MINI brand has been established and there is a possibility of creating new models for new markets, I can see no reason why BMW would restrict itself to FWD models only.
Just my opinion and hopes.
Mini 2 Slap Head
Peeps, just a few points. And, these are just what came into my head after reading all the above, they are not in any way meant to diss peoples ideas or opinions ok :)
1) Mini would not suit a 4x4 powertrain. It would be very difficult to incorporate 4wd into the existing engine/gearbox and short of using a morotbike engine in the front longitudinally mounted, no suitable powertrain would.
2) Mini was created as front wheel drive and unless BMW have engineered a new floor plan for around 2008, i cannot see BMW making a suitable business case for re-tooling a new floor pan. I am certain the demand would be low relative to the number of total Mini sales. 5% maximum 4wd sales would not cover investment costs. No business case.
3) Little benefit in dry conditions. 4wd would only eliminate power-on understeer and maybe buy you 0.5 seconds off the line. Is it worth spending more than the value of a new mini on a conversion that does this? Ok, wet conditions would be a benefit such as pulling out of a T-junction, but, in the dry, ultimate mechanical grip provided by the tyres on a 2wd mini would be no greater than that of a 4wd mini.
4) Modern Evo's and WRX etc. All the road going rally cars i have seen on the limit tend to inherently understeer anyway. Car manufactureres are engineering this into the handling of the car specifically for the 'front wheel drive generation'. Why you ask? Think about it.
5) Performance benefit? Hmmm, increase vehicle mass, double amount of rotating drivetrain, increase friction, lose driveability, lose fuel economy, naaa, it just aint stacking up. If ya gonna be an ice racer or rally-cross racer then its all good, but for driving on ordinary roads, i wouldn't bother.
At the end of the day it is up to the person who has the $$$ and is prepared to undertake such an engineering task. I may appear to diss the idea, but wait, i am an engineer and would amire such a conversion and it owner for taking on the task.
Dont forget peeps, owning a mini is all about being individual, and a 4wd certainly would be that.
C_P
Between the street versions of WRC cars ONLY Impreza and Lancer EVO are 4WD: 206, Focus and Accent are FWD and Octavia is a "false" 4x4 with Haldex differential. For my is ragionally improbable see a 4WD Mini.
About engine, the best solution is a very efficent 2.0 4-inline naturally aspirated likely Honda (240Cv).
V8?? :confused: The only car FWD V8 that i known is Lancia Thema 8.32 powered by Ferrari 328 engine. And it's a **** of car! :D
About a super-Mini i think a 2.0 from 220-240HP, FWD, rollbar, a lot of carbon fiber and very light in philosophy of Porsche Clubsport, Modena Challenge Stradale or M3 CSL.
To go fast add lightness (Colin Chapman)! :D
It would be really cool to see a 4WD mini, but they would have to do something about power output, because remember you are carrying a lot more weight with a driveshaft, different gearbox, and so on that by the end you have got 4WD but you are carrying extra weight that it acctually slows the car down a bit. I would say that they should do something like the Clio Sport. A mid mounted 24 valve V6 engine with drive running to the rear wheels, this would be impressive I would imagine.
Numb from Jäger
I picked up a UK mag called "Racecar Engineering" that had a big writeup on v8 derivitives of common motorcycle 4-cylinders. 2.0L, 300+ hp @ 11,000rpm , 160lbs, small external dimensions. Would make for a VERY interesting mid-engine conversion.
Too bad the motor costs $20,000. But parts are readily available (direct fit from their 4-cyl parents).
The idea of a central engine and rear whell drive in a compact car is very interesting.
The Clio V6 however, is not a good car, often more slow of a Clio 2.0 Rs: the engine is too weight, equipped on the gear box (too high!) and few power. The handling results very bad.
if you want 4x4 you needn't get a BINI get a real mini drop in a golf vr6 engine in place of the backseats and strengthen everything else - would cost nowhere near as much and would go like stink!!!
Snotty Rhinohiney
Cadillac (a GM brand) Deville has had a fwd v8 (4.6ltr) for years. Was advertised as the most powerfull fwd car in existance for a while.
I just read an article in the new magazine GoMini about the heavily modded, blue, Cooper S, and apparently the owner is currently working on a mind-meld between an Audi Quattro drivetrain, and a Cooper S.:eek:
Steve
The MINI Wagon variant mentioned in another thread adds 250mm to the length. Still not enough by about 175mm but if that works then there is no reason you couldn't extend it further.
Mike Cooper and some four wheel drive minis...
From a Globe and Mail article by Brian Harper, on the MINI event at the Col de Turini (Mike Cooper in attendance):
"Some of us think BMW should commit the Mini to a season of competing in the WRC. Mike Cooper says he can put together a team of 360hp, four-wheel drive versions and campaign them for $80 million (repotedly what Citroen is spending to compete this year)"
In case you missed it first time round:
"360hp, four wheel drive"
Now THAT would be worth seeing...
Mini Obsessed
Let's not forget the new generation R56 coming soon! It's supposedly longer and will introduce the new, lighter, more powerful BMW/PSA engines. With the new car might come a floorpan and drivetrain that could be designed from the beginning with an AWD model in mind. I hear WRC!!!
Mini 2 Slap Head
And at the same time as making the Mini cheaper....sure they will
21 - 40 of 80 Posts
About this Discussion
58 Participants
mab01uk
MINI Cooper Forum
Full Forum Listing
