Where is the best place to get some bigger injectors (440 or 450's) from in your neck of the woods?
What prices are you looking at in the UK or USA?
Will they ship down under?
D-MAN
Track Addict
D-MAN
Hi,
PM sent
Robbo
Thanks guys.
Ant FR wouldn't it be better to get the car tuned for the injectors rather than the adjustable fuel regulator?
D-MAN
THE STICK
Yep GTT or ThinkMINI.co.uk also sell them in 450cc, but both recomend the fitting and setting up of a GTT variable fuel pressure regulator as the car will not run right without this. 1320 I believ also do big injectors and use mapping to regulate cycle and various other things to control fueling.... both methods seem to have proven results but there is debate amonst manyu folks on which is better.
not sure either would supply just parts, but they might....as they both believe other things need to be done on the big 450cc etc injectors to controlo fueling.
