body control module and cas unit fault ie the transmitter for key fob and rolling codes specialist job
The second fault below the 9cab is for the transmitter of the key fob?body control module and cas unit fault ie the transmitter for key fob and rolling codes specialist job
every time you open or close car on key fob the cas unit and bcm store and send codes as a rolling cycle to the keyThe second fault below the 9cab is for the transmitter of the key fob?
So the only way to fix that is to replace the footwell module?every time you open or close car on key fob the cas unit and bcm store and send codes as a rolling cycle to the key
really needs tp be taken to main dealer and have it diagnosed with their mini diagnostics tool first off then will know which part of the system is at fault, also might be common issue and their diagnostics will know that and might give a short cut to it, i send jobs ike this to main dealers or to a really good auto electrical guy i use in the uk, as cant just replace it needs to be programmed to car ,, but first off need to know for sure what part is faulty and if its a wiring issues or bcm issues, as the canbus systems all run around that as wellSo the only way to fix that is to replace the footwell module?
Can a faulty FRM can cause to warning like high battery discharge ( cc id 415- yellow car on lift) ?really needs tp be taken to main dealer and have it diagnosed with their mini diagnostics tool first off then will know which part of the system is at fault, also might be common issue and their diagnostics will know that and might give a short cut to it, i send jobs ike this to main dealers or to a really good auto electrical guy i use in the uk, as cant just replace it needs to be programmed to car ,, but first off need to know for sure what part is faulty and if its a wiring issues or bcm issues, as the canbus systems all run around that as well
would suspect alternator before anything else and work backwards towards the frm or jbe junction box,Can a faulty FRM can cause to warning like high battery discharge ( cc id 415- yellow car on lift) ?
And also can it cause the motor to go shut down while driving?
