Hi all im new here. Im having problems trying to diagnose the problem with my abs. Ive tried to diagnose with both of my obd2 scanners but it says not communicating. Ive changed the abs module in case that was dead but still no joy? Help me please!
Have you checked the abs sensors? They can go bad and cause that issue. That would be the first thing I'd check myself
Hi ive changed the front ones and swapped the abs module but still no comunication. On my other mini i comunicated with the abs to find out which abs sensor had gone?
Hi mate have finally got round to changing the rear speed sensors. Turned the car on and instead of amber ans and runflat warning lights the run flat was red. So went out for a run. After a while i decided to restart the car and both lights went out. I was very happy but not for long even though the run flat light stayed off but now i just have the abs light. I tried to read the abs codes but still wont comunicate? Cheers
