Hi, a few days ago my ABS light came on, My car is still in warranty... just. My problem is that i have changed my pads to mintex ones and painted the calipers. I still have the old pads i can put on so thats not a problem but I cant do anything about the painted calipers, will this cause me any problems?
dont want them to say the reason the ABS is faulty is cos i've painted the calipers
What is the problem likely to be? Is there anything i can try myself before i mess about swapping the pads back?
Thanks in advance, Richard
My ABS light came on in my GP that has R56 front brake set up and JCM rears with Mintex pads.
Took it to the dealer for a fix under warranty - ABS pressure switch had failed.
No problems and no questions asked - mind you the dealer knows my car is heavily modded and I have a good relationship with them.
N.O.T.R.A.M.O.O
If your dealer does cause any problems, I would be stunned!
Painting the calipers, or replacing the pads for that matter will def. not do anything to the ABS, the only possible thing I can think you could have done is displaced the wheels speed sensor harness from its mounting and it has now fouled in the wheel rim, but I would think that unlikely.
i'll check if they are all still in place, is it the sensors which have a blue clip? I know the front ones are just behind the wheel arch lining
