Try to clear the light with a OBD2 reader
new.minimania.com
unplug and refit each sensor at it's appropriate wheel. after unplugging the battery for 5 minutes.
Check for appropriate clearances between the sensor and the pickup on the wheel using a peeler gauge.
make sure the geometry is correct on all four wheels as it could relate to the problem.
Was it in a accident is the sub frame straight. Sounds like it would be electrically related. Has the problem been occuring for the last 6 months?
Mini Cooper Obd2 Engine Code Reader & Reset Scan Tool
