Yes.Can this cause the light sequence with the abs, tcs to stay on and low tyre pressure light to come on when pulling away
Yeah, exactly that. I have removed that connection and just done a straight solder. It will mean I have to do the same if it goes again but it’s just one of those things.Dcarter, are you referring to the (usually) blue plastic cased plug around 1-2ft away from the sensor? I have an annoying fault that won't go away. I checked the plugs for cleanliness and corrosion, and all seems OK.
If I stick a multimeter on the main harness at the pump, will that show faulty circuits as open? Or does it not work like that? I'm new to electrical fault finding 😬 my multimeter wouldn't fit in the plug on the sensor side, as it was too deep for both prongs!
abs sensor is a hall effect type, the the sensor and the abs ring generate its own electric from the spinning of the road wheels,, so multimeter on micro volts across the sensor and spin wheel is how can check they generate electric,, but will need a scope or a diagnostic tool that counts the pulses to know if all 4 read the same as they should all read same at same road speed,Dcarter, are you referring to the (usually) blue plastic cased plug around 1-2ft away from the sensor? I have an annoying fault that won't go away. I checked the plugs for cleanliness and corrosion, and all seems OK.
