Wanted a JCW!!
I have an MTX sub in a box ready to rock, what kind of wiring do I need to be able to plug and play with the Mini Upgraded Hifi system? As there is already an amp in the back I was hoping it wouldn't involve stripping the car down.
wat amp have u got in the bak and is it already wired up and got power?? if so wat speakers are u usin to power it?? wats the amp brand and power??
sub power??
may be able to help u out
Wanted a JCW!!
The amp is the one that came with the Mini Hifi system, I'm suspecting I will need another one though.
Wanted a JCW!!
I ran a power cable from the battery through the grommit, and down the side of the car, behind the plastic trim so hidden away. then spliced a rear speaker cable and took a feed which connected into a converter giving me RCA connectors on it. I removed the rear seat and fed the cables underneath and then they basically plugged straight into the amp. Not the best way I hear but the easiest.
