I have problem which 3 warning light on; ASC,ABS,Runflat light.
So I borrowed the GT1 scanner from my friend's neighbor and checked with GT1 scanner.
And I replaced front driver's Wheel Sensor which doesn't work, BUT still these lights on..
My service warranty has expired I don't want to go the dealer.
After replace the sensor, Should I reset with GT1 scanner for turning off the warning lights ?
Or there is no need to reset the fault code ? Should I re-check the sensor has changed correctly?
Plz. THanks :puzzled:
N.O.T.R.A.M.O.O
You should only need to drive the car a few hundred yards to allow the ABS ECU to see an acceptable wheel speed signal to allow the light to go out, but the fault code will ALWAYS be stored unless you erase it with GT1.
If the light still refuses to go out, check the wheel bearing pick up, I have had to replace a few lately for ABS signal plausability faults.
Hope this helps. :)
