1 - 12 of 12 Posts
Guys, hypothetical question here, if the air con is not blowing out any cold air at all, and assuming that a re-gas doesn't fix the problem, what am I looking at in terms of cost to sort the problem out?
I'm assuming that if a re-gas doesn't work, then I'm looking at a new air con compressor, or whatever it's called, anyone have any ideas how much this would cost to fix?
First make sure you are checking with the blower on, the air con doesn't work with the blower off. Secondly if the system doesn't make horrible graunching/whistling/screaching noises a simple re-gas will almost certainly cure the problem. Make sure who ever you use extracts the old gas and dries it before refilling.
  • Like
Reactions: Filbert
And if did... for a while... and is now dead silent, what do you recon then? Dead compressor? (=> replace compresser, dry out, vacuum and refill the gas?):confused:
- MC'02
There may be a leak from one of the pipes, but it most definatelly will just need a re-gas. The re-gas company will check for leaks prior to your re-gas, this is common practice. The compressors (usually) are not prone to brake.
Let us know how you get on. Plenty of cheap home visit re-gass companies in your local paper.
The post was in Sept 2009
Nothing better than a bit of advice for future reference :) To who may read, or have interest!
AC not blowing cold
I have a 2002 "S". I'm also just getting warm air but it does blow cool some days. Yesterday I had cool air, today warm air. Last week warm and cool, never really cold. When I turn the control to warm it really blows warm but when I turn back to "Lo", it only blows warm not cold. I have the little snowflake on too. :confused:
ZahirBaba
Hello room can anyone advice i am having problem with my air condition,compressor is replaced but sill not cooling in fact if i by pass wire from the relay it engages and cools that means i can not on nor off it from the panel inside.all i can do is to increase and decrease the blower speed.
1 - 12 of 12 Posts
