Just thought I’d share what the £30 “airbag deactivation” option consists of on 2005 models. For your money, you get a switch on the side of the passenger-side dashboard trim, which is only accessible/visible when the passenger door is open. The switch is operated by the ignition key, and simply switches the front passenger airbag either on or off.
Also, in the roof console just above the rear view mirror is an indicator that is normally off, but lights up orange when the airbag is deactivated. I’m not sure where this will move to when the clock moves back to the overhead console next year though.
All in all, pretty good for £30 I thought, especially when you previously had to pay several hundred pounds to get the thing deactivated, and then it was permanent.
