Hi
I have a 2002 mini cooper. My issue is that the airbag light is on. code reader is giving error 10/05 - Firing circuit side airbag front left side.
I have read post explaining this is a bad connection under the seat.
My issue seems to be strange, if i clear the error and disconnect the yellow plug under the passenger seat the fault stays cleared. However if you plug the yellow conector back in and turn ingnition on the fault is shown again.
Can anyone explain this? my understaning was that if there was a bad conection i.e not connected the error should show but mine is only erroring when connected.
Any advise would be greatully received.
Thank
Simon
Thank
Simon
