1 - 12 of 12 Posts
Hi Everyone,
Thought it might be interesting for all new diesel owners to share their experiences. The N47 unit now used in Mini Diesel models has been around on the BMW cars for a while and there are threads about the DPF and regeneration and the DPF smelling and the cooling fan staying on when the car is turned off etc.. When I first got mine it did something which caused a right stench like burning, it was then fine but re-occured 200 miles later but not as strong, since then occasionally I notice it but faint. I think its the DPF doing its thing. I also noticed that after having the Auto climate button on but cooling off this morning, when I stopped the car and turned off the fan stayed on for 5 mins. Also noticed the smell at the front end, not sure if this was linked to the auto program or had it done a dpf regen thingy. Anyway the car seems fine but would be interesting to know how other people are finding the N47 in their Mini. I think any R56 LCI Diesel Mini should be the N47 and the countryman diesels use the same unit. :)
We traded our 2009 mini cooper d in for a new mini clubman cooper d our old mini averaged 54mpg the new one only averages a diss appointing 43.7mpg although it is a lot smoother and quieter it also had some nasty squeeks and rattles which Sytners mini did. Not want to fix just said they all do it.
not a very good answer so I ended up sorting it myself
Got a Cooper SD Coupe on loan and it did the "fan thing" to me on Friday... Exactly the same, drove a few miles across town, parked up, switched off and the fan stayed running for a full 5 mins.
Something smelled very hot too.
Nothing untoward since, drives fines.
Mini One D 1.6
N47 dpf
My MINI One D quite often runs it's fan for a few minutes when parked up.
Sometimes it is accompanied by a strong smell of heat.
The car seems fine though.
Chris.
Discussion Starter #6
Thanks for the reply guys! Mine is fine also but when I first got it and had the first dpf regen I got such a strong hot smell it was very concerning. Seems all good though. I'm at 1500 miles now and getting about 53 mpg average. Hope that gets a bit better but from reading the forums I think the quoted 74.8 or whatever it is, is a bit out of range lol!
I saw an interesting detail on Which? magazines tests of the Mini diesels - they got 53.3mpg for the D (vs BMW's 74.3), but they got 58.9mpg when testing the SD (vs BMW's 65.7). Their testing seems pretty thorough - all mpg testing is done on a fixed route at fixed times, so is fairly accurate.
The big shocker was that in testing the new 118d they got exactly the same 64.2mpg as BMW and they actually got better extra-urban consumption than BMW, 76.3 vs 72.4!
I can't see any obvious explanation why the same engine in a 1 series should use less fuel than in a smaller/lighter (though not by much) Mini.
Well, my car had the n47 engine, a mini countryman sd..... Mine did the fan thing, was told by mini it was fine then when I came back from holiday the car was completely burnt out!! Caused by an electrical fault!!If I still had this car I would get it checked out
I've got a cooper d with the Peugeot/Ford engine and it's been great, although once the exhaust burnt and punctured my bike tyre when I was driving to Cornwall. It was about 6" away from the end of the tailpipe.
13 plate SD - had the fan run very early on in it's life (4500 approx miles now 5 months in), noticed it a couple of times but not recently. It didn't seem to happen on really hot days when i might have expected it. is it a known issue that should be seen as an actual problem?
Hi Everyone,
seen a lot of these engines destroyed bmw M47 engine was the better engine, but 2007 they changed to the n47 on bmw cars and later stuck it in the mini,, one big issue is timing chain, they recalled a lot of them the first n47 engines after which done a story on the massive amounts of chain failure from 40k most lasted 70k, they blamed the owners for poor servicing and engine oils etc the norm,, so dpf blocks up this adds even more carbon in the oil and more heat in the engine added the chains are thin and narrow,, then just to add insult to it all the put chain on rear of engine so engine out job for a t/chain replacement.. some customers would ear the noises and think it was a dual mass flywheel issue until they snapped.. i have had bmw m47 cars with 200k plus still on same chain, i have never seen a n47 make it this far unless driven like a vicker with 5k oil services maybe.
seems to me car makers all get together and find ways to ensure their products all fail with same issues, dpf. egr. timing chains. waterpumps run off timing belts. daul mass flywheels,, very expensive weak sensors and fuel systems,, body control modules,, and as many parts as they can that need special encoding to replace,,
Are you aware of BMW replacing any engines for free? The timing chain on my Countryman just snapped and garage told me I need s new engine!!
1 - 12 of 12 Posts
About this Discussion
11 Participants
Ret180305
MINI Cooper Forum
Full Forum Listing
