Hi,
just found a quite interesting list of all MINI suppliers (quoted from AUTOMOBILPRODUKTION, June 2001 (www.automagazine.com)):
Alpine, J - ICE, CD, Navigationsystem
Alps, J - electric switches
Antolin, GB - roof-module, dashboard shelf
Arvin Exhaust, GB - exhaust
Austria Alu Guss, A - alloy wheels
Autokabel, D - battery cables
Autoliv, f - airbags, seatbelts
Automotive Lighting, D - headlamps, fog lamps
Benteler, D - (Querlenker)
Bloxwich, GB - bonnet lock
Bolton Plastics, GB - air channels
Bosch, D/E - starter, airbag electronic, locks
Bristol Bending Sanoh, GB - brake pipes
calsonic, Wales - cooling system, oilcooler
Collins&Aikman, GB - door opener (inside)
Component Metal Pressings, GB - pressed parts
Continental Teves, D/GB - brake system
Decoma, GB - front/rear bumper, exterior plastic parts
Delphi, F/GB - aircon compressor, suspension systems
Denso, USA - generator
Donelly, IRL - interior mirrows
Dräxlmaier, GB - harness
DuPont, D - paint
Dura, F - handbrake
Elring Klinger, GB - sealing systems
Elta plastics GB - handles
Fagor Elderlan, E - brake disks, chassis parts
Faurecia, F - plastic components for front end module
Federal Mogul, GB - head rests
Fico, E - sunblinds
FTE (Dana), D - clutch operation (hydraulic cylinders)
Fuba, D - antenna, diversity system
Gate, Wales - ventilator
Gates, E - drive belts
Gerhardi, D - chrome exterior parts
Getrag, D - manual 6-speed gearbox
GKN Hardy Spicer, GB - drive shafts
Goodmans, GB - speakers
Goodyear, GB - tires
Hanns Glass, D - carpets
Harman, GB - speakers (premium ICE)
Hayes Lemmerz, I - wheels
Hydro Automotive, GB - bumper carrier
Infast, GB - mounting parts
Intier, GB - cockpit module, door trims
Isodelta, F - steering wheels
Johnson Controls, GB - seats
Kautex textron, GB - washing system windscreen, headlamps
Kautex Unipart, GB - fuel tank
Kostal, D/IRL - electronic controller (rearview mirror, rain sensor)
KSM, D - engine carrier
Küster, D - window winder
Le Profil, GB - exterior plastic components
Linden, D - badges
Linpac, GB - exterior plastic components
LUK, D/H - clutch, torsional absorber CVT
Magna Mirror, GB - exterior mirrors
Metzeler, D - door/bonnet sealings
Midland Powertrain, GB - manual gearbox
MKL, D - interior trim
Motorola, USA/F - pressure sensor, central body electronics, gearbox management (CVT)
Muhr&Bender, D - stabilizing strut (?) (Stabilisator)
NGK NTK, J - oxygen sensor
NSI, GB - instrument cluster
NSK Steering/NSK, GB/D - wheel bearings, steering wheel column, steering spindle
Paulstra, GB - rubber bearing, gearbox carrier
Peak Automotive, GB - flywheel, (Halter Querlenker)
Perei, GB - interior lighting, side indicator lights
Phoenix, D - cooler pipes
Pirelli, D/GB - tires, wheel assembly
PPG, D - paint
Rehau, GB - rear spoiler, (Hutze)
Rieter, GB - floor trim, sealings
Sekurit Saint Goban, D - windscreen, side windows
Siemens, F - engine management controller, impulse sensor ABS
Silvatrim, Monaco - roof trim, underbody trim
Souvtec, H - wheels
Stabilus, GB - gas springs for bonnet, boot opening system
Stadco, GB - (Pressteile)
Tennex, GB - air intake muffler, air intake pipes, resonator
TKA (Camford), GB - rear axle carrier
TKA (Tallent), BG - front bumper carrier, front axle carrier, (Längslenker)
Trico, GB - rear window wiper
Tritec Motors, BR - 16V-engines
TRW, GB - switches, plastic fittings
United Parts, GB - gear shift system, door opener
Valeo, F/D/GB/E - wiper motor, aircon condensor, tail lights, indicator lights front, reversing lights, brake lights, park distance control, clutch clima-/heating system, aircon control unit, wiper arms, door locks, door handles, generator
Varta, D - battery
VDO, D - radio/CD, Navigation electronics, intake valve throttle
Veritas, h - fuel pipe systems, brake pipe parts
Wagon Automotive, GB - (Pressteile)
Webasto Roof systems, GB - sun roof
WHS Smith & Sons, GB - shift knob
WKW KTR, CH - A-,B-,C-pillar trim exterior
ZF Lemförder, D/GB - automatic shift system, chassis parts
ZF Lenksysteme, D/B - electro-hydraulic steering system, CVT gearbox
quite a lot!
j.:)
