1 - 1 of 1 Posts
hi,
my asc+t light comes on after hard acceleration. restarting the engine clears it. i've had 380cc injectors/jcw air box/exedy clutch flywheel fitted and a belt change recently. looking at other threads on here i assume i'm ?hitting the boost threshold.? my car originally had a morego conversion (stage 2 - cylinder head/19% pulley/cam/miltek manifold+catback)
asc+t light didn't come on that often. now it's every day since the new parts were fitted at lohen. they checked the fault code - said there was an abnormal signal to the DME???
not sure if it's just a case of exceeding the boost threshold or it's something else ?sensitive MAP sensor/ ?wheel sensors, wheel bearings recently changed.
what do people think?
should i just ignore it?
1 - 1 of 1 Posts
