I have an autocom cdp+ with Delphi 2015 ver 3 on my laptop
connects ok from laptop to car but...
Dont seem to be able to watch live data with it.
Wanted to look at the info from upstream and downstream o2 sensors to see whether readings were mirrored and cat was knackered
Will this set up give live data that I need. Which settings do I need to go into to read this
on first screen select car and petrol or diesel and engine type, then connect you then get first screen with left side pane read codes etc, on the right hand side bottom corner there are 3 buttons with graths pictured on them one has the + sign on it click this, this will bring you to a page with a list of sensors and controllers double click or high light the ones you want or all of them so they move from left to right pane once done this re-click on the grath locking button at bottom right of screen, now you will have either a grath or if click on the other bottom at bottom of screen it will change it to numbers
Is it activated?
I think I can see your WIFI is connected.
I was recommended to disable all internet connections when I use this software.
This is the screen I am greeted with once I have selected car type. Both no graph in 3 buttons in lower right. Any ideas
on this screen select your car and engine type and petrol or diesel, or even better put your chassis number in the big box at the bottom and it will find it, you will have option to read fault codes next read them on this screen, this will give you the screen i have already told you about to access, looking foe red buttons with pics of graphs in them
should not have internet on, or anti virus, never try and up date it,
below link will help,
https://www.youtube.com/watch?v=sxjLBGE8rHU
Discussion Starter #6
May have found culprit
Got the autocom up and running and choose to view cylinders 1 to 4
Number 1 showed a misfire along with a 2772 code permanent misfire on cyl 1 ( this then went intermittent when I swooped cyl
I then removed the ignition coil from the top of the spark plug on cyl 1 and swoped it with cyl 2.
The misfire moved to number 2
Tried on 3 and 4 and the misfire moved with the coil
So I have come to the conclusion it's a failed coil pack
Do these have to be changed in sets or can I just do the one
I believe you can just change the faulty one out, but if you don't know the previous history of when they have last been changed swap all four for new ones.
they do recommend changing all at same time with spark plugs, but in practice rarely do as cost as fair bit. see with out that autocom finding that fault would of been a battle
