1 - 17 of 17 Posts
Hi, I am interested to know what type of prams/pushchairs people are using. I am looking to buy one and cant seem to find that many that fold down enough to go in the boot of my cooper.
Thanks in advance for your experience.
MINI2 No.1
Hello there, try a search for 'buggy', there's been quite a bit of discussion.
It looks like we'll be going for the MINI Isofix car seat and the Mama's and Papa's Aria buggy for our little one (due end of July).
Although I have been told the Maclaren Mac 3 will fit, as well as a Mothercare 'own brand' seat that I've seen.
We found two that fit, one was a Mothercare branded one and the other was the Mama's and Papa's Aria.
We have gone the the Aria as the Mothercare one seemed to a bit flimsy. We have also got the Mama's and Papa'a Prima Viaggio (spelling???) car seat with the fixing base.
One word of warming though - You may have problems getting the single Aria push chair as it is not a standard catalogue item. Only the double ones are in the catalogue, but the stores get sent odd batches from the manufacturer, hence you cannot order them. All you can do is keep checking with your local store for when they get some in.
Hope that helps
Mark.
MINI2 No.1
Hope that helps
Mark.
Better not say were I found the Aria then. ;)
Quick question MarkMINI, does the Aria go in 'flat', or do you have to put it in on it's side? I forgot to check last time.
Thanks.
Paul
Paul
It goes in on it's side, and the fact that the handle slides down to make it fold shorter means it also fits in if you have CD multichanger installed as well.
Hight wise, it was a very close call, so close that I am a bit concernd that the extra HK speakers in the rear parcel shelf might cause a problem...
O well, too late know to worry!
Mark.
Only problem we've found with the Aria so far is trying to find a buggy board to fit, but that will be a couple of years down the line for you if this is your first one...
The Maclaren Volo fits in the boot diagonally if you remove the parcel shelf. The advantage is that other things can be fitted in the boot arount this pushchair because it is so compact and light. Well made too....
Mamas & Papas Aria Advance Pushchair
My wife after leaving a company car scheme has opted to purchase a Mini Cooper, having a 3 month old baby it was not the most practicle option in my opinion. After a test drive I changed my mind due to safety features on the Cooper.
This led on to the how to transport the kid around in it.
We currently have a Mamas & Papas MPX chassis & travel system (car seat, cot, chassis, pushchair etc.) and were informed that M & P sell a pushchair called Aria Advance which would be compatible with the M & P kit already purchased (car seat, footmuffs etc).
These pushchairs can be purchased through " The Pram Centre" across from the Barras Glasgow.
Banned
I am guessing that is the Glasgow Pram Centre, great store, excellent staff.
Might also be worth asking to see the new Silver Cross Compact Stroller, this also fits in the boot of a MINI;)
Hi i have not any idea about baby pram but i want to suggest you that you have to go in the market. There are many different types of baby pram available with good colour, design and also low weight. You can easily buy you choice baby pram form there.
Youve just replied to a question asked 9 years ago :aargh:
Paul
Hight wise, it was a very close call, so close that I am a bit concernd that the extra HK speakers in the rear pa xender discord omegle cel shelf might cause a problem...
Mark.
I thought it would be side on only, not much room for anything else....
1 - 17 of 17 Posts
