And my friend the tribologist take on the article above:
"The conclusion is 100% correct in its basic statement in that PROVIDED YOU MATCH VISCOSITY AND ADDITIVES- (I guess that’s what they are calling certifications?) they are all virtually identical in terms of service and protection.
Then they lose all credibility but I understand why- they are sampling oil samples ONLY and not matching the oil sample to the actual machine and considering how its used, maintenance record and other factors so their data is “skewed”
In a lab or in a car- oil change frequency is the single most important determining factor in reducing engine wear.
After that comes the loading ( heavy towing, racing, mud bogging, fuel leakage and so forth) This is where synthetics come in- they don’t lubricate BETTER but they lubricate better UNDER EXTREME CONDITIONS ( but if those conditions don’t exist in your driving then you will see a minimal benefit)
THAT’S when those other “things” matter. Also as an engine wears and its clearance opens ( you still have an oil pump at a set pressure and flow) you will benefit from the thicker viscosity for the hydrodynamic wedge.
The name brand is meaningless as far as an indication of quality- whether it carries an ISO, API or SAE rating does matter.
I use Mobil 1 exclusively ( since I cant get ultrachem right now) because it’s a true Grade IV PAO synthetic base stock ( as opposed to a highly refined Grade III mineral) and on the farm it protects better. ( except in diesels, Rotella is still the best formula )
The important thing is to stay away from those additives like slick 50, STP, Lucas and so forth unless you really have a worn out engine you are trying to get the last vestiges of life out of
That’s my take on it."
Joe McKnight MBA, CMRP, SSBB
Reliability Engineer, SME
