Why not buy the roof rack and 2 bike carriers for around £230 including postage from Woodman's?
http://www.mini2.com/forum/derek-woodman-mini/167095-r56-cycle-rack.html
Why not buy the roof rack and 2 bike carriers for around £230 including postage from Woodman's?hi
i want to fit a bike rack on to my mini but i dont want to buy the one from mini as its nearly £400 .I have used other racks from halifords before on other cars but my car as a spolier fitted which i think will be a problem does anyone know of a rack which will carry two bikes and fit the car with out damaging the spoiler
thanks
Not sure this is true. The factory fit roof rails for the clubman are just that and different from the roof rack which does fit into the roof channel apparently they are fiddly to fit I'm not sure if there are plugs for when you take the roof rack off. I suggest you speak to Woodman's (and I'd be interested in what they say)the way i understood about roof racks on mini is that you need to spec it from new as it fits into specially cut groves in the roof channel .I also need it to be able to fit a number of different minis as there are 3 in my household and we are planning on using the different cars each time we need to use the rack.
thanks
If all the Mini's you have are R56's, they're all pre drilled, so you don't need to spec when new - they're located under the gutter cover which requires cutting in two places each side. The rack comes with plugs to cover the cut outs when not in use, but you'll need a few sets if it's for more than 1 mini. I'm hoping to get one soon too.the way i understood about roof racks on mini is that you need to spec it from new as it fits into specially cut groves in the roof channel .I also need it to be able to fit a number of different minis as there are 3 in my household and we are planning on using the different cars each time we need to use the rack.
thanks
Hey Jason,I have a boot mountable bikerack, which was purchased when I had a R53 but have since got the R56 - factory JCW with the rear spoiler.
There is bodywork, but the skin is beneath the spoiler panel. So the spoiler is attached to the outer body surface which is attached to the door skin... I only know this because I've seen a couple of Mini's driving around with only the door skin showing! Whoops!So are you saying that if you remove the rear spoiler - as in the 5 screws underneath - then there is no bodywork above the rear window. Hope you understand what I mean!
Thats the scariest feeling! It wouldn't be so bad if it was just the bike falling off - but could cause deaths too, and of course damage to your Mini!!last thing I want is to see my carbon road bike falling off the back as driving along and getting crushed under the unsuspecting car following:aargh:
