1 - 11 of 11 Posts
You gotta love the toys!!
Hi all,
Having tried some cheap (and not great) Bluetooth streaming USB sticks via aux I finally decided to try something a bit more permanent and bought one of these:
Bluetooth Handsfree A2DP USB SD AUX CD Changer Adapter Interface Car Kit For MINI Cooper R50 R52 R53 Boost Radio https://www.amazon.co.uk/dp/B06XXX9QRM/ref=cm_sw_r_cp_apa_i_WpyACbPESAVNE
Was sceptical but it is actually very good. Easy to fit and both music and phone quality are impressive. Nice touch that you can balance the volume to match the radio.
I mounted the main box in the glovebox, put the mic next to the rev counter and cable tied all the loose stuff behind the dash. Only complication was figuring out the adapter box needs to get stashed above the head unit as there's no room below.
/R
Sent from my Pixel 3 using Tapatalk
I have one and it’s great, there’s a cheaper Bluetooth only version if all you want is BT music streaming.
Decided to splash out for the hands free - now Android Auto works brilliantly as sat nav, music and phone. Super happy for £50.
Forgot to mention that it utilises the steering wheel buttons to fwd/rev a track or pickup/hangup the phone.
/R
2012 R56 S
“New to this forum, is there a version for R56 ?”
I second this question. I’ve got a 2012 S R56 with the HarmonKardon option. No Bluetooth and no USB. there’s a hands free law, here, so I’m looking hard for something.
Hi all, Im new to the forum. Just bought a 2004 MC as a run around and something for my partner to learn to drive in. I want Bluetooth just for phone calls. Im not bothered about playing music etc, just calls. I have the standard MINI stereo fitted. Whats the best way to achieve this? TIA
There is a variety of bluetooth dongles that are cheap and does the trick. All you need to do is connect one end to your aux in below your A/C and the other to a light charger. You get crystal clear audio and easy connection. The only problem is; it's a bit hard to have a conversation via phone since the mic is further than it should be and you need to power it on after starting your car. Still a cheap and effective solution. There are tons of models out there but here are just a few:
These thing constatly change and improve, so it's worth searching "bluetooth aux" keywords every now and then...
Review and purchase the one you desire :)
1 - 11 of 11 Posts
