Boot floor retrofit
16973 Views 24 Replies 8 Participants Last post by  Lea_t_bail20
Hi guys weve just ordered a countryman and it doesn't come with the false floor wasnt going to pay for the heated seats and other bits we dont really need just to get that and the armest has anyone retrofitted the flat boot floor or armrest on the f60
1 - 20 of 25 Posts
Made my own. MDF 18mm out of homebase and covered it with waterproof canvas and stapled it underneath and put a bit of velcro at the back to stop it sliding when dog jumps in. As the MDF was an offcut Homebase only charged £5. The canvas was about £15 and already had the velcro and a staple gun so £20 and done the job nicely. Didn't fancy paying the £900 for the comfort pack.
Hope this helps.
You can occasionally see them on eBay, I just bought one for £53 - when it arrived, one of the location pins had broken, so I actually got fully refunded - all I did was drill a hole into the broken pin and connecting rod, screwed them together, created a ferrule out of a large rawl plug (same internal/external diameter measurements), and it works perfectly! :)
Really, for the F60? Never seen one for that. Thought you needed a whole kit for it to fit.
4
Well, I think mine is an F60, and all I needed was the cover as you can see in the photos
I think that's the older model my friend. The f60 is a different set up
Aha.... I knew my model number had '60' in it, just the letter was different! :)
  • Like
Reactions: 1
Hi
I am same as you these are the only two things I want on our recently purchased countryman.
After intensive research, I found the boot floor, looks fantastic, ordered,coming from Italy,
I will let you know on actual quality and fit once it arrives!! Hopefully by next week!
The armrest !!!! There are so called retro fits, but I am not sure on fit and durability!!
Therefore I have decided to look into buying a central consol with the armrest used condition then find a mini person to install it for me!
Adam ,
6
I've just fitted the arm rest the other day. I'd seen some sellers on ebay selling they full tunnel frame but I looked back at exploded drawings a guessed i didnt need the whole thing. It was easy to fit. Just needed to M6 bolts to attach:
It came with the mobile charger within but mine didn't have the wiring loom under so i'll just adapt that later on from the main fuse box when I get them time.
Matt
Great job
I was about to buy the frame with armrest today but now not!!
Where did you purchase the armrest from ! What part number year etc is it!!
Did the back unit just clip off
Thank you
Adam
I think there are two different arm rests. I got 9373771 with the wireless charger but it was the only single unit available at the time. I got it for £100 on eBay. Cheaper than these other "full kits".
The rear panel pops off easy.
You need to pop the side panels off a little to get at the screw on either side. This allows the central bin to lift. You can then pop the blank on the top with the two screws.
It was a bit of a faff getting the side panels on correct.
Hope that makes sense
Sent from my GM1913 using Tapatalk
Super thanks Matt
Appreciate your reply
Will,let you know about boot floor when it arrives next week
Adam
7
Super thanks Matt
Adam
Hi Matt
Hope all is well
It arrived yesterday well packed
10/10 for packaging, quality of product, nice weight and fitting
Makes life easy now with shopping etc etc and it looks neat plus the wife's likes it!!!
Only 1 left in stock
Hi Matt
Hope all is well
Can I ask where you found this? Trying to find something similar and zero luck so far!
Hi, I’ve just bought the countryman f60, it’s a 2020 plate, will this fit it? Does it rattle in the boot? I’ve been trawling the internet and can only find this, thanks
Hiya
No rattle
Its perfect weight
Its a excellent product you won't be disappointed
Adam
Thank you! This is my first mini and I love it! Just getting used to where reverse is on the gearbox 😂
1 - 20 of 25 Posts
