2009 Mini One 1.4 petrol r56. 6 speed
Have had a nightmare to say the least!
Bought with misfire and long story cut short piston 4 near enough melted and head past the point of repair so managed to get hold of second hand engine. Changed all anciliarys over and did timing chain as it was ‘down on power’ but ran. Fast forward engine in and running all seemed good no eml lights etc. Went and put petrol in about a mile down the road and went up the slip road for the motorway not under any major load 2500rpm I hear a ticking and then what I can only describe as bottom end knocking. Got it back to the workshop checked timing at crank and cams with special tools and all was ok new chain, tensioner etc all see perfectly fine no signs of oil starvation. Realised chain for oil pump had major slack in it but after doing some googling I beleive this is normal so had sump off to look to see if crank bearing had spun and low and behold all seems fine! No scoring etc and seem to be getting plenty of oil. Turned oil pump by hand after removing and spat oil everywere so presuming that’s all good aswell. But there is lots of tiny bits of swarf in oil and cannot for the life of think what to look at next as nothing obvious is standing out. also have had it running without alt belt and tensioner to eliminate that. Noise doesn’t go away with clutch in.
Ran generic diagnostics before I did anything and had misfire on all 4 cylinders with a vanos fault but dismissed after checking timing.
Can crank pulley sprocket ( bottom timing chain sprocket) be on backwards if this is a thing and spin on crank any genuine help would me very much appreciated! Completely lost next step was either push it in a river or put shells in and hope for the best before it goes in the river because it owes me about 30 hours labour
