Brakes
791 Views 3 Replies 3 Participants Last post by  Mindav02
Hi guys I’ve been working through various faults with abs and brakes in general, I’ve bleed brakes and get a good pedal until I turn engine on then pedal goes soft and I get a lot of air noise under dash , is this normal or do you think it could be faulty master or servo ,
servo leaking would guess or the pipe feed to it
  • Like
Reactions: 1
If your servo is leaking your engine could be running rich (assuming it feeds the vacuum to the servo).
When it went for m o t they said it was high on emissions, so could be
