I have noticed that our discs get a bit corroded if left even just overnight in rain.
First few times you hit the brakes the next morning it sounds rough.
Dave
Dave
you mean you don't use the handbrake when turning?fearofmanc said:The handbook suggests a light application of the handbrake when coasting to a stop,
I read this too... It's really bizarre - are they suggesting that the rear pads NEVER touch the rear discs when you apply the foot-brake?!!fearofmanc said:The handbook suggests a light application of the handbrake when coasting to a stop.....
For all those people withkjs said:
you mean you don't use the handbrake when turning?![]()
Cheers Mr. Spaceman - You are a mine of info - Are you Mr. Haynes in disguisespace_cadet said:Not bizzare at all.... In effect the internal surface of the centre part of the disc is used as a drum.....
If you look at this cutaway view from the MINI2 gallery, it looks to me as if the MINI has a dual-cable, lever operated mechanical actuator acting on the same rear disks, that the hydraulically operated road brakes do. (inboard on the rear caliper)Originally posted by space_cadet
Not bizzare at all, as the handbrake does not use the
rear disk and pads at all. In fact there is a more traditional brake drum and shoes used solely for the handbrake.
space_cadet said:Not bizzare at all, as the handbrake does not use the
rear disk and pads at all. In fact there is a more traditional brake drum and shoes used solely for the handbrake. In effect the internal surface of the centre
Hi Karmuzekarmuze said:Hi orie!
This can lead to a different pressure applied to the pads on the rear calipers. Take it to your MINI dealer and have him put it right.
