brembo brakes ????
1452 Views 13 Replies 5 Participants Last post by  pangster
are these brembo brakes please ??
276438
1 - 14 of 14 Posts
what they doesn't have any marking on them? or on the box?
someone sent me this pic , they said they are brembo and will fit my 2007 mini cooper s , but im not so sure , and my wheels have only 4 wheel nuts , thanks
You’ve answered your own question, even if they are brembo, they don’t fit your car.
i would say could be as the front are indeed 4 piston calipers as brembo upgrade as the standard mini fronts are floating calipers single piston your pic shows clearly these are not and are fixed type where the pads are the moving item only so yep would be a good upgrade even if were not brembo and were factory upgrades stil a good upgrade to have for track days. also would say are later gen cars 2010 onwards by stud patterns and being 5 stud
i would say could be as the front are indeed 4 piston calipers as brembo upgrade as the standard mini fronts are floating calipers single piston your pic shows clearly these are not and are fixed type where the pads are the moving item only so yep would be a good upgrade even if were not brembo and were factory upgrades stil a good upgrade to have for track days. also would say are later gen cars 2007 onwards by stud patterns and being 5 stud
A gem 2 Cooper S is 4 stud, not 5, the discs certainly don’t fit.
countryman maybe 2010 onwards
Thanks everyone for all your input ,much appreciated , I now know they dont fit ,thanks
So why ask?
next
  • Like
Reactions: 1
The pad retaining clip is brembo.. can make it out from the pics.. so they definitely look like brembo calipers.. although, as confirmed... Not for your car..
  • Like
Reactions: 1
1 - 14 of 14 Posts
