1 - 14 of 14 Posts
Hi ive had my 2009 mini cooper 1.6 d only 7 days no problems its going really well 72,300 miles on the clock, im based near wickford essex ive booked my mini into a garage in rayliegh near by for a cambelt change, the guys there are fitting a cam belt kit, water pump and auxilary belt price is £ 427 with a two year 30,000 mile warranty providing i bring the car back to them every six months to check it over, i had prices from other garages rangeing from £280 to £550 this seemed a good deal to me il let you guys no how it goes
No problems, ive had so called bmw specialists telling me its a chain
the 1.6 hdi engine is a psa engine and does have both ie a chain that links the two cam shafts within the head and a timing belt on front of engine thats also runs water pump. 150.000 miles they say on change times but the water pump wont last that long rule of thumb 80k change both the camshaft chain they also say 150k have seen tensioners fail around 80 k before and the chain eats through the rocker cover and gets a bad oil leak tends to be first sign of it failing,
post march 2010 they changed to the bmw n47 diesel that has a timing chain mounted at rear of engine these snap or slip after around 70-90k and are so expensive to change as its a gearbox or engine out to do so,,
your engine is psa one its also got a dpf filter in exhaust as well as additive tank in rear that needs refilling every 45k and reset the counter at same time failure to do this will result in blocked dpf this can lead to turbo failure that leads to diesel overrun and end of engine , ford and volvo use same engines they put this filter at a service replace item at 75.000 miles ,, many people have had them removed and mapped out and this just makes the car so much better, but s a mot failure but mot is a visaul check so just remove the internals and have mapped out cant tell as filter is in in two parts,, its possible to buy a element for the filter on ebay £120 ish the additive is £20 litre ish takes just over 2
mike1967 thanks for the info, i did no there was a chain across the cam sprockets but i read the change time was 125000 miles or 10 years which ever comes first for the belt, ive also read that the addative is stored in a black plastic box with a bladder inside the box, is it possible to change the bladder my self? will i need to reset any lights that might come on after changing the fuel addative bladder?
its possible to buy a kit to reuse the old bladder again if its not split but most do, worth ringing ocean bmw in plymouth parts department recently i have had a number of parts off them and been fairly cheap and genuine is a bonus, its the fluid that is so expensive also be so careful handling it its poison that will soak through you skin ie no skin contact,, as for resetting the counter in the ecu the cheapest and best diagnostic tool and easy to use compared to anything else is autocom cdp plus link below for a double circuit board full function one .
cheapest dpf filter element below,
the best diagnostics you can get for money and will works on anything on the road read and write and live data etc
added note after fitting new dpf need to also with autocom reset the ecu ie tell its got a new dpf i also force a regen on them to clean out the top cat and turbo vnt after fitting a new one then reset it all again as such autocom will do it,
thats great mike thanks for the info and fast reply, its people like you that make it worth joinining forums on the internet
thank you glad could help,
if were my car would have it deleted its mot failure but its a visual check it cleans them up so much and can drive low revs where good mpg is without blocking uot the dpf filter, had both mine done on the past also had last one turned up to 160bhp ish transformed it in fact that car seen it last week still bombing around guy said its been great no problems which is nice to know,, but that was 68k car with full history when done,, would think twice if any car is over 100,000 miles or if ever had a turbo melt down in the past always needs to be a right car if that makes sense., if not just do the dpf delete and egr.
Discussion Starter · #12 ·
well mines done 72000 miles good service history and i must admit it does pull really srong through the gears it suprised me when i first drove it home, ive had alot of diesel cars the only small one was a Mg zr 2 litre d, i think the mini will rev up higher than the mg but the mg felt alot lighter car, id like to have the dpf removed deleted but im unsure of the whole prosess really the reason being is ive just never worked on modern cars and electronics, my other car is a 1972 mk2 triumph 2500cc saloon i have a 6m square garage which ive fitted gearboxes diffs camshafts cylinder heads most stuff really but its all just nuts and bolts, so id need some where near me to delete the dpf that i can trust im based in wickford essex near basildon southend on sea and chelmsford, would the mini still run ok if it wasnt remapped after deleting the dpf?
no must be mapped and codes removed from self check all mapping company's do this and can do been doing them for years, the bonus ball is the oil stays clean as well also the turbo spools up early on a sound a car this can be increased as well,
i have this guy called dale its top bloke with ecu's etc and i send a ecu off to him he deletes and maps it sends it back all i needed to do was remove the filter and blank the egr never had a problem doing that its easy delete on them no welding of cutting just big hammer and chisel and 10mm socket and 13mm one for the strap around it, as filter is two piece, by deleting egr valve this stops exhaust gases ie around 15% in the combustion chamber ie this gas dont burn its inert so when deleted you notice a bitter pick up, the above is for anyone who has min mechanical nohow its fairly easy with some tool and axle stands etc,
Discussion Starter · #14 ·
Thanks again mike il get the cam belt changed first then think about deleting the dpf
1 - 14 of 14 Posts
