1 - 14 of 14 Posts
Hi
So unfortunately i kerbed it the other day :( second time on the same wheel (second time ever since ive been driving infact, both with mini :mad:)
does anyone know if this can be refurbished, or do i need to buy a new alloy?
cheers
thanks for replies and for recommendation..only thing is that refurb place is in Kent, a couple of hours drive away from me.. would i have to leave the car there or can they refurbish the wheel in a few hours??
Loving his JCW!!!
where are you - someone will probably be able to recommend somewhere more locally. I actually think that may be repairable by one of the mobile smart repair people - they push the tyre back, repair the damage, and then paint only the damaged area. Usually works out far cheaper than having the trye removed, the entire wheel blasted, repaired, and then recoated/painted.
Discussion Starter · #9 ·
thanks for the help! much appreciated! will see if their is a mobile repairer around my area if not ill be down to the place in kent! cheers!
Discussion Starter · #12 ·
lol :D sent an email to chips away for a quote, depending on how much they price will determine which place i go with. either way ill post pics once they are repaired! cheers for all the help
That's definitely do-able. I run my own business doing these and other cosmetic stuff etc. all the time. Don't know where you're at but lots of specialists will sort it, no problem.
1 - 14 of 14 Posts
