Hello,
I was cleaning my girlfriend's mothers Mini Cooper S Convertible and we got a idea to put the roof down, so we can see more (it was already dark). After cleaning up we wanted to put the roof up - without touching the car with water.
Any suggestions? Can it be from the temperature? It was around 0 degrees Celsius.
Two levers in the trunk are where they should be.
Nothing is stuck there.
Tried even closing the roof with the key in the door, did not work.
Thanks in advance :)
you can manually close it with the crank located in the left side boot behind the panel or use a screw driver to disengage the gears on both sides where the bend in the guide arm (just behind driver and passenger door frame). Then with a friends assistance you lift both sides at the same time and fully close the top and lock in place.
About this Discussion
1 Reply
2 Participants
nealwm
MINI Cooper Forum
Full Forum Listing
