1 - 14 of 14 Posts
If money isn't a concern, then I won't have any headache.
I just place an order for a MCS. But I still can't decide which tires to go. I know the best solution is performance plus an extra set of snow tires. I don't have any problem to shed $100 for a piece of snow tire, however these run flat are so expensive. I had think about just go for regular snow tires, but I need to have room to carry an extra tire, which is not quite possible.
So I place my order with all season. However, after I know more about how heavy the tires are, and they are from 'Good Year', the more I don't want the all season.
Currently, I am in Wisconsin. It may snow 40% of a year, so I can't drive with slick all year round. :confused:
I had great traction with my all season run flats in all weather but even in snow i sometimes had to put the chains on(i have air suspension on my cooper ad when raised i've got a good 10-14 inches of ground clearance,therefore i can drive through pretty deep snow)and that was only when it was like 8 inches.So in my opinion get the.The tires are definetely abit heavier and aren't as good as hving rain spec tires,slicks,and snow tires but they are the nex best thing. :)
What is the best MPG you get from the heavy all season tires? I really concern about how the weight of those tires impact the mpg, and the traction in 3 to 4 inches of snow. Lucky you can install chain, we can't do that in here.
Is there way that I can put regular tires and fit a small donut under the trunk? My concern is run flat is expensive and heavy. If I can hide a small spare tire without sacrifice lot of space, then I would go for performance and snow. :(
Sure, get a Cooper instead of a MCS ;) .
Seriously, I don't think there is a way around this unless you want to give up 75% of your actual boot space to a spare, or find runflat snows (do they exist?).
Is there a noticable difference in handling and/or ride quality between the All Season 17 and Performance 17's? I'm thinking performance unless the handling is the same and the ride is better.
No room for the spare in the MCS
francisk said:
:confused:
So cooper has the small spare tire? Why MCS can't? :confused:
The battery in the MCS is located where the spare is in the MC. They moved the battery to make room for the supercharger up front.
A fair trade I'd say! :D
I have the all-seasons, and they are pretty good all-around. But we get almost no snow here in Seattle, only a lot of wet, so they are a good compromise for here. With a lot of snow, I'm not sure what I'd do.
As to answer your question about mpg.I would say at max they take away no more then 2 mpg because my MCS got on average my first year with them about 32mpg.And now i have these performance rain/street spec tires and i get 33 with them average.lso as far as MCS owners needing to carry a spare tire(I believe 2 should always be on hand cus if one can pop then so can another)i uses a bike rack holder wich goes on the back and has two prongs that stick out of it..you've probably seen one by now.anyways i just put my two wheel/tire assembly's on that and strap them down with tire covers over them.here's a diagram:
@=circumferance of tire
*= two protruding rods from bike rack wich wheels sit on.
p.s. you can also buy a kit where you strap it to the edge of your back door and it only holds one tire but it works.i think jcwhitney sells them.sorry for the bad diagram.
1 - 14 of 14 Posts
