dave316 said:
I just got my 05 MCS this weekend (ill post some pics soon)
I never drove stick before. While im not doing that bad for my first time - i only put about 15 miles on the car - i cant figure out first gear. Im fine in every other gear, even reverse for some reason...
Ive tried giving it a lot of gas and a little gas to start out, i always end up having the car jerk on me. I have no idea of how to coordiante both feet to have the clutch come up and the gas go down, every time i do that the car lunges forward. It takes me about 5-10 seconds to get the car moving from first(that doesnt include shifting)
it seems like theres no in between in having the clutch all the way out and having it all the way up.
i cant seem to find a consitent method, i feel like im just getting lucky when everything goes right. And whenever i screw up i get annoyed because i know im kicking the crap out of a brand new clutch and transmission. I either lunge forward or stall (or get lucky) nothing to extreme hopefully not damaging...
What is the secret to first gear in this car, im in a helpless state right now
Hi Dave,
Learning to two with both feet is an interesting task. A new clutch driver has the tendency to let the clutch out "too fast." A new driver "usually" does one of two things when starting out in 1st gear. Two things happen when you fall into this pitfall, 1) the car jerks/lungs or 2) the car stalls. Every once one in a while you get it right and go forward fine. But I found this to be the biggest issue when overcoming the fear/frustration of 1st gear.. When you try next time, you need to shut off all sounds within the car so that you can listen to what it is trying to tell you. This is where the quality time with your car begins. Just you and it.
Driving with two feet is a give and take relationship. When starting out in first, you have to give the car enough gas/air to want to move forward (gas pedal). Letting up on the clutch pedal, you slowly start to engage the transmission and the car moves forward. Give too much gas and you chirp the tires, give too little and you jerk/stall.
You have to learn the "feel" of the clutch pedal (the resistance level). Once that is accomplished, work on letting the clutch pedal up very slowly. I stress slowly! Now try it with the car running... Rev the car to about 1500rpms, and now that you mastered the clutch pedal, let it out slowly. You will start to learn the "point" at which the clutch engages the transmission and the car will move forward.
This is where it sometimes gets tricky for new drivers in that you have to monitor two things at once now, while watching for traffic/pedestrians. 1) Where are you in the clutch pedal motion, and if you are releasing it slowly 2) and what is the current engine rpm. As you slowly let the clutch pedal out, the car's rpms will start to drop a little as the car starts to move forward. Feel free to give it some more gas IF/WHEN the car drops below 1000rpms so that it does not stall. Remember to continue to let clutch pedal out slowly at this point. New drivers have the tendency to shift focus onto the gas pedal now and forget the clutch by releasing it all the way now, hence, the car will chirp/lung/jerk. Or, they get nervous and over rev while still letting out the clutch. Practice, practice, practice. As you get the hang of it, you will start to learn how to get the vehicle moving at 1000rpms, or 2000 rpms, or just letting go at 3000+ and roasting the tires. Or the ever popular, getting going while on a upward hill at a stop light and the person behind you is up your $^&! Always exciting!
Stalling the car is a byproduct of letting the clutch out and not giving it enough gas. The lung/jerk is a byproduct of letting the clutch out too fast and pushing on the gas pedal out of rhythm. It has to be a smooth motion, as one pedal comes up, the other will be going down. No jerky movements. You need to learn this rhythm in order to smoothy launch the vehicle.
There is a second method, but your transmission/clutch will not like it. That is starting out in second gear from a stop. A little more difficult, but allows you to get the idea of what as to happen from a stand still without the car being as touchy as it is in first gear. It forces you to give the car gas while letting the clutch out.
You will probably be slow at this for a little while, everyone is! It is kind of like learning to walk again, one foot in front of the other. While difficult to grasp in the beginning, look at what you can do now, you can run!
So, in conclusion, what I am trying to say is.... Get the car to 1500rpms, slowly let the clutch out, as the vehicle starts to move forward, the rpms will drop, push the gas pedal in about 1/4-1/2 inch, continue to let the clutch and begin motoring.
Let us know what happens! And if this rambling made any sense or helped out! It is 1125pm now, and time for nighty night!
Best of luck!
Some good articles as well:
http://www.10w40.com/individual/100186.asp
http://www.standardshift.com/faq.html
http://www.ehow.com/how_3234_drive-car-with.html
