The dealer changes the oil at 15K miles. So presumably the filter is also good for 15K miles... I've got spare mobil1... If I wanted to do a quick oil change and not mess with the filter at 7500, would that be terribly bad for some reason ?
tuscan_thunder said:my thoughts are that if you change the oil more regularly than advised, and use an engine flush, then just change the filter at the stated intervals.
engine flush is a couple of quid for a can and is simple to use.
better doing changing oil and not filter than not doing either. it's not going to do any harm really is it?
