Yeah & and 1 hours labourtimlowden771 said:I would say the best bet is to go to your dealer. There are lots of wires down around the lights and If you pull one of those out by mistake you will be in even more trouble. The dealer should only charge you for the bulb.
Hi I agree with Shooler it aint that bad once the liner is taken off. someone said to me that you have to take the front bumper off and there is a tread for that someone on this mini2. also iin the manual it states contact dealer.You don't need to remove the front bumper. Turn your front wheels to gain access to the fender liners and unscrew the plastic clips that hold it in place. From there you can reach behind the liner to change the bulbs. It's very easy and doesn't take long.
