1 - 17 of 17 Posts
HI I am looking at a 5 plate Cooper and having taken it for a drive have noticed that it is a bit noisy/clunky whne driving; could this be the anti roll rubber or worse? TY Gaz
Could be anything drop links
Arb bushes
Worn track rod end
Track control arm ball joint worn.
It's hard to tell unless you pull the wheel of and have a butchers
Sent from my GT-N7100 using Tapatalk
I've got the strut top mounts to do on my R50 as it has a wee tiny clunk on the front right shocky but will do it when I can be bothered. The car has been sat parked up in the garage for the last 7 weeks doing hee haw so there's no rush lol
Charlie wants them done now
If you don't he will get upset
Cha is just the reserve car Henry and only really sees action if any of the Dooper's are receiving maintenance or if he's loaned out as a courtesy car. He barely covered 3000 miles last year between mot's. He's only really been on the road for 3 months this year to cover for Hamish when he was away getting his warranty work done at bmw
My mini sid has been pulled off the road after developing a knock when cold
Hoping it's the guide rails
Have you checked the tensioner? (Chain)
Replaced the tensioner 3 days ago still no change, I will pull the valve cover to replace the guide rails as a precaution
I will make a video in a day or two so you can hear it
A new set of followers lol. Pull the cover off and give it a good inspection
i was thinking about the guide rails, if it were them that are faulty wouldnt the noise be constant? coz it disappears after 40seconds ::smile::
1 - 17 of 17 Posts
